Configures a list of I-SID numbers that represent local or remote Layer 3 VSNs to which the IS-IS accept policy applies. After you create the list of I-SID numbers, you must then create, configure, and enable the IS-IS accept policy.
When creating an I-SID list, you can add I-SID entries until the maximum limit for supported Layer 3 I-SIDs is reached. The system truncates any additional I-SID entries. The maximum limit includes the I-SIDs for locally configured Layer 3 VSNs and the I-SIDs specified for IS-IS accept policy filters.
Refresh the EDM tab to view the actual list of I-SIDs in the I-SID list.
  • Enable IS-IS globally.
  • Ensure the manual area exists.
  1. In the navigation pane, expand Configuration > IP.
  2. Select IS-IS.
  3. Select the Isid-List tab.
  4. Select Insert.
  5. In the Name field, specify a name for the I-SID list.
  6. Select Isid or Isid-List.
  7. Specify an I-SID number or a list of I-SID numbers.
  8. Select Insert.
Isid-List Field Descriptions
Use the data in the following table to use the Isid-List tab.
Name
Description
Name
Specifies the name of the I-SID list.
Isid or Isid-List
Specifies that you either want to add a particular I-SID or a list of I-SID numbers.
Isid
Specifies a particular I-SID number or a list of I-SID numbers that represent local or remote Layer 3 VSNs to which the IS-IS accept policy applies.
An I-SID value of 0 represents the global routing table (GRT).
